1 - 20 of 76 Posts
Hello,
So I have done a little research into buildiing a motor for these horsepower numbers searching other forums, mostly mustang, but wanted to get your guys imput. I will leave the question pretty general. What is the best way to get that kind of power in our cars without putting forced induction on it. Can this be done with heads, exhaust, internals, and the like? Also I am in cali so I have smog to deal with. Anyone in cali that has done something like this that is good to go through smog as well?
Not on a 2V. Forced induction is the way to go on a 2V. Even a 4.6L 4V it's hard to get those 350-400rwhp numbers without forced induction. Those are really high numbers for a NA motor, because you're talking about 450 hp at the crank which is more than what even a new Mustang puts out with a 5.0, 4V, variable valve timing and so many more innovations.
Better to plop down 3k on a supercharger setup, it's the only way to go for those kinds of numbers.
It won't happen NA with the 2V, what you need to even get 300 at the wheels certainly won't pass smog. Save up for a blower and take it off during inspections.
Not on a 2V. Forced induction is the way to go on a 2V. Even a 4.6L 4V it's hard to get those 350-400rwhp numbers without forced induction. Those are really high numbers for a NA motor, because you're talking about 450 hp at the crank which is more than what even a new Mustang puts out with a 5.0, 4V, Direct Injection, and so many more innovations.
The 5.0 uses port injection, only the newest 2018 is getting dual(direct/port). The VVT plays the biggest role in the 400+ numbers.
What kind of hp can stock internals take?
And lets say I do heads, nothing crazy just a little improvement, and internals that should not mess with smog if I take the supercharger off during smog testing correct?
Plan on getting a set of Trick Flow heads- then add in what you can afford.
Whats your budget? And why stay NA?
I just like the idea of all motor. But if thats not possible I dont mind the blower.
As far as budget 3-5 grand. Of course cheaper if possible, but I dont mind spending the extra money for reliability. I want reliable power.
What is it that really messes up the smog. Would cams do it?
Yes, you'll never pass the sniffer test with lumpy cams, and additionally you'll need longtube headers(not shorty or midlength) to take advantage of the scavenging the cams allow, and there is no way those will pass CA smog, exhaust alterations before the cats are a BIG no no.
The internals generally seem to be able can handle just up to 400 rwhp on boost before connecting rods perforate the block, 350ish is definitely safe and reliable. You'd want two tunes, one a NA tune for smog purposes, and another one with the supercharger installed.
My junk makes 348 at the wheels @ 6500rpm, with VP E-85.
But it has a big cam, big intake, big compression, big heads and big cubes.
Pump E-85 for fuel. Street driven, still. But why?
Any more HP and you lift the engine into a higher rpm range, that I was trying to stay out of. Trick Flow had an advertisement in Race Pages, (the NMCA magazine)
that 5.3L, 4.6 engine made 518 HP and 417 ft/lb torque @ 7000 rpm.
This probally will not pass a smog check.
I'll try to post the ad on the TCCOA facebook page.
Here-
OOOhhh! Impresive.
Nice 3" headers. Wow that's a lot of flow.
If Oscar gets his heap together and on the road we may see about the best an N/A 2v 4.6 with PI heads has to offer... :)
Thanks for pulling up that ad.
GM's HP and torque should be higher and at a higher RPM.
OOOhhh! Impresive.
What you been smoking Monkey? 3" inch exhaust not 3" headers lol! Besides that's a nearly 50 cubic inch bored and stroked motor over a 4.6 so it should do something.
One bad ass set of cams in it too.
I was with trunk monkey- I figured they were using 3" collectors.
They are 1 5/8 headers and may be 3" collectors. Then a 3" exhaust. They sure aren't 3" headers.
Regardless it made very good power.
Was that in a Mustang??
LOL!! I'll probably never see it ROFL!!!
I've done had one heart surgery and another associated surgery and have yet to see his done and mine's almost ready.
It would be interesting to see though.
I'll never tell ya what I've been smoking :tongue:
Yea, yea, you know what I meant ... 3" exhaust. My bad. I didn't type it that way.
But yea, wow, those are beefy cams.
Theirs: .625/.625 lift, 252/256 .050 duration, 113 LSA
1MTNCAT: .550/.550 lift, 234/238 .050 duration, 113 LSA
Mine: .536/.540 lift, 228/235 .050 duration, 114 LSA
For yours I pulled the cams from your gallery/garage and looked up the Comp Stage 3 Stats. http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=969&sb=0
The difference is you guys are N/A, I've got a blower. :D
1 - 20 of 76 Posts
