My fan is making noises. Sounds like its loose and is banging on its enclosure. I will be checking it out tonight after work.
If I have to replace it, I sure would appreciate input on what to do or not to do and what to look out for.
Many thanks.
the fan and shroud i beleive are one piece. its cake to remove, unnbolt the upper brackets, unplug and slide out. to install, just reverse.
joseph
i would get one from a junkyard, they usually last the life of the car.
Real simple to remove it, just unplug the battery before you start messing with it.
I think its four bolts, and unplug the connector.
Simple two minute job.
JH
