Hello, I am looking for any advice about replacing my tranny in my 94 LX (4.6 V8). I just got some things done to get the car running right (need to update my previous posting) but now the tranny seems to be slipping. It does not seem to be running in synch with the motor. At a stop it hesitates, kicks a bit, and slowly brings up the RPMs before it finally seems to catch up. There is definitely a problem with it, Should I look for a used one to swap out, my local mechanic suggested a flush, new fluid and filter, but couldn't gaurantee that it would fix the problem.
Thanks for the help.
Jeff
Change the fluid using Mercon V "drain the torque convertor it has a
drain plug" uses about 12 qts.
When changing fluid it is a good idea to also change the 1-2 accumulator &
springs "under $20.00" Go to the Tech Article page click on Transmission
very good stuff :)
CurtisA
ct to mi, long ways, but id go for that, slap a cooler and j-mod on millers tranny, and youl be good for a while after that, but what ever you do, get the CEL off before you go for sevre stuff like tranny, your problem may be in your CEL, ud be suprised how funny a car can act with a bad sensor
Thanks for the info, sorry but what is the CEL. I am still getting used to the T-bird lingo.
Thanks
Jeff
Gotcha, I am getting the car re-coded this week. I will have my mechanic write down the code\codes.
