1 - 10 of 10 Posts
Well I took the car to the girlfriends last night.. First time I really drove the car for more than 2 mins.. I get to her house everything seemed fine.. I leave 3 hours later, she's following me due to xmas shopping. I start to smell oil, I check the oil pressure gauge and wham like 5psi.. I pulled over a second later, look under the car and there is a giant puddle of oil.. I hope that just the sender that blew out due to too much pressure or somthing.. This car has been problems since the first day I got it!!!
Fry Rice Specialist
is it the pi engine?
Eleventeenth Gear Poster
Wow, I think you may actually have worse luck than me. I didnt think it was possible. Good luck with whatever it is....I still say you should sell me the car cheap :)
got under her and the oil pressure sender snaped off.. I dont know if its faulty metal in the adaptor or not.. i gotta find somthing stronger.. i should be able toget a easy out in her...
Is this a sender for an aftermarket gauge? Is it installed in the bottom port of the oil pump? If so it most likely hit the k-member as a result of the motor mounts compressing under load as you went over a bump. There may seem like there is room there but there isn't, don't ask how I know...
-Miller
KrAzyT said:
any idea how to get it not to happen again?
Well I have yet to attempt to reinstall my gauges but I am going to try swapping the stock sender to the lower position so that the aftermarket one can take its place.
-Miller
did you tap that downward facing pipe plug off of the OEM sender housing?
it was facing downwards with 2 90degree bends.. A 45 would have been great if anyone had anything around here. I should be able to get it all fixed up ok. I just wanna see some pictures if anyone has them of how to have it not hit anything
1 - 10 of 10 Posts
