Im doing a suspension rebuild on the daily driver (97 Thunderbird). I cant for the life of me get that lower ball joint to drop out of the spindle. Im replacing the whole arm with a brand new lower control arm from MOOG. New bushing all around.
Do I need a press to get that pOS out?
Im using a tuning fork and a big hammer. That doesnt seem to be doing the trick.
Before I pull another muscle anyone have a tip for removal?
drag-aholic
what about beating the spindle with a sledge hammer near the balljoint hole? Leave the nut on loose so what it pops it doesn't fall apart
i would think a pickle fork would get it, especially if you aren't worried about saving the balljoint
I am pretty sure I used the same tool for the LBJ to spindle, tie rod end to spindle, end links. I had zero luck with a pickle fork, only succeeded is destroying the boots. I also didn't have much luck with loosening the nut 3 or 4 turns and beating on it with a hammer, but I didn't try real hard because it was pretty much 2 seconds with the tie rod end tool.
4 or 5 bucks at harbor freight, used on three complete mn12 front end swaps/replacements, and still could be used again (but the pointed end is getting deformed).
OK got it.
Now....how about those control arm bushings up front. How do those come out? THe doughnut looking ones.
****and in case this is ever searched. I used leverage. Jacked the car up a little higher, slipped a bar over the fork, hammered it in as best I could and jumped on it. Worked great.
