PIP and check the coil
been there done that, pretty much all of it so far.
Plug in the mapclean the MAF
You should be named the resident diagnostic. You solved all your own problems. Hmmmmmmmmm, a Mark VII with a stick, cool. Great work.The high idle was a vacuum leak. The hoses running to the MAP sensor and the charcoal canister were both broken open at the nipples under the manifold. It's idling ~700 rpms now so I'll take that.![]()
