this may be a silly question. but i wanna get black lug nuts since they would go better with my black cobras. but i just dont kno what size to get? what size are they? when u go to summit theres a lot to chose from. any input would be great.
black lug nuts
gorilla automotive makes black lug nuts. check with them online to find your closest vendor
when installing, put a sandwich bag over the lug, and then slide a six point socket over the top to protect the finish
lug nuts
those will work fine, make sure to run down by hand, then hand torque with
a baggie over the nut to prevent finish from coming off-tire baron
ok cool. i was just a little bit iffy cuz they were the closed end kind.
lug nuts
yes they will work with brad's wheels, he can get them for you - cardinal rule:
never, never put heavy lubricant on wheel studs with closed end nuts...clean
and dry threads only otherwise torque will be altered - tire baron
Thank You! I will throw one in the glove compartment!
Brad
