M5R2 Tailhousing Assembly
The M5R2-rke tailhousing assembly install starts with cleaning and
inpecting for worn or damaged parts.
The extension housing contains a bronze alloy bushing. This bushing
cannot be serviced.
The extension housing must be replaced as a unit if the bushing
requires service.
The Tailhousing detailed instructions are HERE.
Shifter Rail parts.
Installing the tailhousing rear oil seal.
Note: The seal has a drain hole and it must be installed on the
bottom.
Install shifter plate before the shifter rod.
Seal the cover with Assembly sealer to prevent leaks.
MN12 Performance Inc. www.mn12performance.com |
