hey guys on the stock crank pulley do i need to take out the big one in the middle or just the 4 outside ones thanks
JUST the 4 smaller ones, 13MM head I believe...........
CatBird Creator
hey, i just bought the set of u/d pullies too. i just wanted to ask before i even attempt this, where are you coming from to get at the bolts? above or below the car? also, can I do it with a racthet set? I dont have an impact wrench, but i want this pulley on there. i have the belt too, everythings ready to go on. thanks
Kyle
I went in from below the car... you'll need a a small extension maybe and a breaker bar unless you have an impact wrench.. just loosen the four outer bolts.. then push on the tensioner, then take off the belt, then take off the four bolts and pulley, then put on the new pulley and put the four bolts back w/ loctite... then put the new belt on...
