1 - 2 of 2 Posts
how much HP can our stock maf can handle?
imho, 24 pound injectors are at the limit of the stock maf.
If it goes lean, that would be bad. :)
The one on my pi swap is an 04 gt 6 pin maf. It has a cone filter from a gt, and I modded the notch on it so it went thru the hole into the fender, as does our stock filter box.
I cut the rubber tube to be ~1" below the old deck, and there's not a lot of air gap.
I'm going to make a seal plate for it out of RTV. :)
We discussed this upgrade here:
http://forums.tccoa.com/showthread.php?t=143820
1 - 2 of 2 Posts
