uGH!!! The god damn threadlock Ford uses on those damn screws must be the strongest stuff available! I managed to get ONE screw out, and the other is stripped so bad I can't even attempt to get it more than halfway out. Great. I can't get a hacksaw blade behind it either.
I think sears sells a kit that attaches to a drill so you can get out striped screws. I hope thats what you were getting at. Im sure there are other ways but thats the only thing that comes to mind.
I tried that before, and the drill's too big to get around the screw.
If it's halfway out, the battle's more than half won! You could try using a cutoff wheel to (carefully, very carefully ... don't lose a finger) cut a slot into the head. Then you can turn it with a flathead screwdriver. Or you could just use visegrips, etc. and beat on it until something happens. I would try to get the whole thing out intact rather than cut it off, because it will only be harder to extract with no head.
Confirmed V6 Nut
Veg,
I've got a spare 70mm MAF housing I could send you. You could get regular screws to put a new MAF sensor in it. I'll let some MAF guru tell you if you need a different MAF than your stock one to use my housing.
Most stores call them "easy outs" or "screw extractors" i bought a cheap set that came with 5 sizes of extractors and matching drill bits. Drill a hole down from the top, put the extractor down in the hole and drill away in reverse. its like a reverse cut drill bit that bites down in the hole you drilled and turns the screw. Good ole tamper proof stuff.........
