1 - 20 of 25 Posts
don't see why not, i was gonna do the same thing
Fry Rice Specialist
don't get it!!!
i have a pair brand new sitting in garage as of right now. too big to fit into our car. you can put it on but it'll scrap like bulldozer to the ground.
get those smaller round one instead.
So I could run cats that are like 5 1/8" wide and 4" Tall! I want to run the cats that are 2 1/2" In/Out!
go w/ the magnaflow. I have a true dual set-up. custom fittings may be nessessary to install but is worth it. (I spent $250 on my custom exaust, cats went out, spent $108 on two magnaflow cats, then $182 to install) F***ING EXPENSIVE, BUT WORTH EVERY PENNY!
sorry to restart the thread again but whats the difference between two way converters and three way converters, bcuz i need to buy new cats to replace the front two on our car thanks
How much would a average exhaust shop charge to weld high flow cats and cut off the crapy stock ones??
For your needs, I wouldn't even bother. You need an entire exhaust upgrade to keep up with the breathing capabilities of your AED. A couple of high-flow cats in that otherwise restrictive 2" exhaust system isn't going to make much of a difference.
I was thinking just pipes instead, but clamped on, so when i get tested just hook up the cats
Mod Motor Cat said:
Ahhh, sorry Ox. I thought you still had the crummy little 2-1-2 sysem our cars came with.
But what do you think, should i open it up alittle more? delete cats, and strait pipes in back??
1 - 20 of 25 Posts
