i have cats. with dual in dual out ''powerflow'' muffler..same muffler prolly 2.25 pipe..i wanna hear it without cats too. ima going to do mine with no cats when summer rolls around
jda95bird said:Anybody running this setup? Every pic I've seen or thread I've read has the di/do with cats. My car doesn't have any cats and I was thinking about going to this setup. How will it sound? I have 2 1/2 inch pipes ran already with magnaflows in the back and the di/do in the middle. I went this route so not to lose too much backpressure with the 2 1/2 inch pipes. It's just not loud enough and I'd like to remove one or the other.
I'm using the 5x8x20 SS model. #14468.fluvannabear said:Gentlemen:
What size DI/DO did you use? Not sure about the 4Hx9WX20L Oval fitting. Of course would be 2.5ID. Have a '92 Sport. TIA. Burt
My exact plans. Nice. It'll be cool to have a sound clip before I get mine done. Except I have cobra cams and ported everytyhing so it'll sound slightly different, but probably not by much. There's a local guy from MN with that setup but with stock cats and it sounds awesome, not too loud, but not too quiet. But the cats quiet it down a lot too.Toombs said:Thomas -
I'm doing mine in a couple weeks (as soon as my backordered muffler shows up). DOHC, stock manifolds, 2.5 duals, no cats, 4x9 DI/DO Tru-X Magnaflow, and that's it. I'll let you know how it sounds. I'm thinking it might be a little loud, as I think that's the smallest Magnaflow you can get with the Tru-X in 2.5 DI/DO configuration. Most here seem to be running the 5x8 Magnaflow, which is 4 inces longer. Bigger muffler typically=quieter. We'll see how it turns out.
Mike
