get a simple 12 volt test light, pull the cover from the map lights/dome light and check to see if they're getting power. If they are then somehow you blew both bulbs simultaneously (sp?) (at the same time
) Don't laugh, I've seen it done.
Using the same test light, check power at the fuse box. Thats about it for my ideas. Use the light to check the switches?
