1 - 2 of 2 Posts
Hi All: Car's been sitting about 1 year while in various stages of replacing both head gaskets. So I decided to complete the job finally and I'll be damned if it didn't actually start. So it's running (rich) but I have what I think is the MAP sensor left over. Neither of the two manuals that I have clearly illustrate where it goes where the vacuum tube comes from. Also have an open fitting on the exhaust manifold return to throttle body. I may actually have some of the vacuum tubes mixed up. Haven't run codes yet cause doesn't make sense until everythings plugged up.
Thanks.
The open fitting on the exhaust return connects to the EGR sensor (called a transducer in one of my books). The EGR sensor (if you aren't familiar) is the grey squarish plastic thing near the throttle body. Anyway, on the bottom of this is a fitting and there should be a 6 in. rubber tube connecting it to the exhaust return. Hope this helps.
Perch
1 - 2 of 2 Posts
