can't a marauders computer be used for a dohc swap? I was thinking that you can use a 2001 cobra motor and a 4r70w and use the marauders harness and computer and make it easier to swap. but I don't know if a marauder uses a 4r70w or not. can anyone answer that question?
Thanks I thought it would work. that would be alot nicer than using a mark VIII's and a cobra's harness and making it work.
I'm not very familiar with the layout of the engine harnesses, but is the MAF harness part of what you are referring to? If so, wouldn't it be on the wrong side of the car?
