What exactly is the engine in the Marauders? what is the difference between IT and a 4.6 in an MN12? Thanks!
marauder tc's are almost identical to mark viii tc'sNot to mention a different [higher stall/smaller] torque converter...
the tc is not part of the engineNot to mention a different [higher stall/smaller] torque converter...
The Marauder motor is pretty much a 32V 4.6L Mustang Mach 1 motor with 5.4L DOHC Lincoln Navigator camshafts. Yes, the throttle body faces the driver's side. My dad also has one. For it's size, that car can move.
The 2000 Cobra R made 390 HP N/A with a 5.4L DOHC.The 4v loves boost actually I'm not sure if I've ever seen an N/A 4v make much more over 300 RWHP,
Ah, I learn something new every day. lol I was told by someone that the 5.4 camshafts were used to account for the heavier weight of the Marauder.All the stock 4.6 and Navi 4V exhaust cams are the same spec, the 96-01 Cobra got bigger intake cams is the only difference.
Actually, while my dads marauder is a few feet bigger than my bird, its about 100 pounds lighter... i have a 97, shes a fatty. The marauder only weighs like 4600. I mean yeah thats not a race car weight, but my bird hit the scale around 4700..My dad also has one. For it's size, that car can move.
I might not have been too helpful, but im 18, id hate to think thats oldMaybe we can take this a little farther.. get some info out of these old guys (*cough* I mean older)
a stock 97 does not weigh 4,700 lbs, unless you have sand bags all over the place, lolActually, while my dads marauder is a few feet bigger than my bird, its about 100 pounds lighter... i have a 97, shes a fatty. The marauder only weighs like 4600. I mean yeah thats not a race car weight, but my bird hit the scale around 4700..
Yeah to be honest it ran the 13.9 once, nice road, shes never been to a track.. We timed it down the road a few weeks back, 14.1. Its about 330 horse with a diablo chip as well, should probably mention that.
One things i wish my bird had, besides that DOHC, is the ride the marauder has. Although 3 days ago we had to fix the air ride, here's another interesting fact about the marauder, when you use a non-stock air ride switch in the trunk, for the air ride suspension, you have to mount it inverted or it wont work... Never found out why, as i think the marauder is the only one that is this way..
But for the week that the air ride was down the rear axle was locked all the way up, its ride still was as smooth as the birds. Which compared to my sisters sebring is incredible![]()
