MAMN12 Posse Member
Mark 8 oil pan, pickup tube, and pan gasket. It has a fitting in the front of it for the Vortech drain line. Perfect for any Vortech users, or you can plug it up.
Great condition, no rust or dents.
Make offer.
pics of pan
What size is the hole on the pan?! 3/8?
MAMN12 Posse Member
It's a fitting in the pan. You could take it out and weld it over. Or find a plug and screw into it. Or it'd be good for you to use as an oil return for your turbos if you could find a Vortech oil return. Yes, the hole appears to be 3/8".
