Mark VIII fan help
It appears that i've drawn a racing crowd with my question on the fan, although my Bird is not a track car, it does have some mods that make it run hotter than your normal street car, as if the 3.8 does'nt run hot enough without any mods.
I heard from the 5.0 guys, that this fan is the only way to go to keep cool. So i figured if the 5.0 guys are keeping cool with it , it should do wonders for the 3.8,right?
I did a google search and found a site link that explained how to wire it to a 5.0 mustang, but it only gives instructions on how to wire it for constant cooling(always on). I would like to hook up a thermostatic switch that would turn the fan on at 190*.
I also hear that this fan draws a lot of amps. I dont think i'll have a problem with that because i have a 130 amp alt. I guess my question should have been...
1) What is the center pin on the fan harnes receptical for?
2) How would i hook up an air conditioning relay to it?
3) what size in-line fuse should i use so i dont fry the fan?
Thank you for the information and suggestions.
BKLYNBIRD
93 lx 3.8
8.8 3.73 trac-lok rear
msd 6 ignition
taylor plug wires
colder plugs
tranny and oil cooler
royal purple fluids
custom cold air intake
1.8 roller rockers from Morana
soon to all be cooled by the Mark VIII fan.
i have no idea of the horse power, or torque because i never dyno'ed it
