Does anyone know the flow rate? A friend of mine had his pump go out. He as a the same modifications as me minus the throttle body and plus a adj. Fuel pressure regulator.
He wants to up his flow.
What year Mark VIII?
Well it's actually a bird but he wants to know if putting in the mk viii pump will up his flow rate
It should work, just as long as its not a second gen mark viii fuel pump. Just make sure you use the tbird o-ring. But your better off going with an aftermarket one from walboro if your going to do any kind of modding. There no sense in putting a new one in only to find out your not getting enough fuel pressure. Just my .02
