Tube for HO pump I assume, the motor is a4.6 DOHC Cobra motor 15/16" OD tube.
It is going into a 92 SC Bird so I had to change the K member and oil pan, the Cobra pan doesn't fit the Bird, and the regular 4.6 pick up tube is too small for the Cobra oil pump.
I couldn't find a Mark VIII pan so I made a kickout on a 95 Cougar pan that holds an extra quart bu I haven't been able to find the pickup tube to confirm it will fit yet
Sounds OK, but first I need to know the OD size and if it will fit into a 94 Cougar pan. Are all the pans are the same because of the K member?????? except the Mk VIII which has the kickout for an extra quart. I have made a kickout on my pan that holds just over a quart so should be OK for the 4V.
Blair
