1 - 2 of 2 Posts
I'm wondering if there's a definitive answer to the question of IRS pinion on the Mark VIII IRS.
I've read everywhere from zero (0) to negative 3 degrees to it doesn't matter.
Here are the specific questions I have:
  1. Does the pinion angle on an IRS matter
  2. What is the default pinion on the Mark VIII IRS
  3. If I transfer the IRS to another vehicle build, does that pinion change per the angle of the engine?
Any insight is appreciated.
The pinion angle must be equal and opposite to the driveline angle. If swapping into another vehicle, you will have to measure the angles and adjust them accordingly to get them to match.
1 - 2 of 2 Posts
