Does anyone have the procedure to check for a bad mass air sensor using a volt/ohm meter? (97 v6)
Thanks
Dan
97 Tbird LXv6
i think there's a tech article on that. look under there or run a search
no prob man. most stuff like that is in the tech's
"The voltage at terminals A and B with engine on should be 10.5V
The voltage between C and D should be .34 - 1.96 V at idle.
If not you may have an electrical prob in the sensor head. "
I'm getting 14.0 between A and B and .90 between C and D...
Is it dead?
Thanks
Dan
i have no idea, i'd have to read the tech article and try to decipher it.
Well, 14v is higher than 10.5... Wonder if I could splice in a resistor...
Nah, gonna replace the damn thing.
Dan
Hooked up an OB2II scanner and got the following:
p0102 mod$10
MAF or VAF
A
Circuit Low Input
p0141
02 Sensor Heater
Circuit Malfunction
Bank 1 Sensor 2
then same, Bank 2 Sensor 2
Then it repeated the codes again for a total of 6.
Dan
