Confirmed V6 Nut
What does the "Calibration" tag in my driver's door jamb signify? It has the code 7-16F.
Also, on the other tag with the VIN #, under the heading SPR, I have the code CCMM. What does that mean? Thanks.
The calibration is a means of identifying the right PCM to buy if you need a new one. There were various calibrations, usually just 2 with the newer cars. It was either Federal (7-16F) or California (7-16P) emissions.
The CCMM is most likely the spring code.
Confirmed V6 Nut
Chris,
So, this 7-16F is the code I'd give if I'm buying an Xcal2 or Xcal3? Or do I have to rip out the kick panel to see the code on the computer box?
The catch code is on a little sticker on the passenger side, just under the edge of the hood, where the rubber gasket under the window meets the side, kinda near the hinge.
Nice thing to know for Junkyard searches. :D
Confirmed V6 Nut
Oh, Thanks Grog! My little sticker says RCX5. Is that a "good" catch code, and does it mean anything other than this is the computer we have left to stick in a V6?
I don't have a clue about what it means, but the tuner guys would know; the code tells what kind of EEC it is, apparently.
I wonder if it's the encryption key; :) Hmm, I need to yank my eec and copy the eprom chip...
