Finally got to changing the tranny fluid to mercon v. Dropped pan and drianed to tc. Does shift smoother now but still acts wired dropping out of overdrive didn't do the mlps. Wondering if it wild be it. Anddddd go
Finally got to changing the tranny fluid to Mercon V. Dropped the pan and drained to tc. Does shift smoother now but still acts weird, dropping out of overdrive. I didn't do the mlps. Wondering if that would be it.
Sounds like it to me.
How did you make out with the MLPS?
Just a thought: Have you ever dropped the pan, pulled the valve body, and checked the O/D servo for wear?
If you've never done this before, get good instructions. When you re-install the O/D servo, the servo pin has to be engaged with the O/D band.
My first time, I didn't know this, and the trans would shift into "neutral" instead of O/D. So, I had to pull the pan/valve body and O/D servo again, and install correctly.
