So, I'm up to my eyeballs into this Coyote swap and what was supposed to be easy part becomes a stopper.
Engine mounts/plates from 4.6 do not bolt up to Coyote. Pattern on plates the same but the TBird plates have bumps and turns and will not mount flat on Coyote block. Halfway into making new engine mounts, the Coyote will not go into TBird K-member. Rear sump of oil pan is too far forward, and I replaced oil pan with a Moroso pan that's more friendly as sump is back farther. Still need to come forward 1-2" to get engine in same spot as 4.6.
I see other MN12's with a Coyote swap but they all used an aftermarket tubular K-member. I know there are none made now but before I go and start cutting the stock K-member, I am wondering if there are any out there that might be available? Complete?
Most I see are AJE, but just wondering if there were any others, and only be used ones?
Everything else, and there's a lot, is shaping up nicely, really enjoying this project but this hit is kind of hard.
Any thoughts would be appreciatted..... Andy
