They should fit, the O2 sensor connections are the same.
Those are easy to make; it's a 1M resistor in series with the signal wire, and a 0.01uF capacitor to ground on the eec end of the resistor.
It has to be waterproof; I'd make sure if I bought a set they weren't full of salt, and were waterproof. :)
The ones I bought failed in a snow storm; I bought a tuner instead. :D
I had a feeling they would work the guy selling them says they won’t fit but I’m sure he’s just covering his butt because he’s not sure if they will work. I’ll have to find out if they’re waterproof I didn’t even consider that as an issue, thanks for the heads up. I’m sure they’re easy to make but for $20 plug and play I’ll pay the little extra for the convenience fee. Thanks for the replies guys.
So I purchased and installed these mil iliminators and now I have both p0420 and p0430 codes pending, I thought these were suppose to eliminate those codes. Do you guys have any idea why I have both coming up now when I didn’t have them before. It’s like the opposite effect happened.
