1 - 2 of 2 Posts
5w30 Guzzler
can someone please confirm if these are the ONLY parts i would need for the most minimal jmod you can do. (this does not include drilling the separator plate)
if i chose not to get the deep sump pan, mess with OD, mess with reverse, leave out springs. would i only need:
1-2 Accumulator F7AZ-7F251-AA $10.32
1-2 Acc Cover F4AZ-7F247-A $3.60
2-3 Accumulator F7AZ-7H292-AA $5.33
16? qts mercon V (tranny cooler going in)
thank you in advance for any help i am given.
Get the pan, you'll thank your self later. You don't have to get the pan with the drain plug.
OK, Here goes:
1-2 acc...F7AZ-7F251-AA
1-2 TOP SPR... F75Z-7F284-AA
1-2 BOTTOM SPR...F7AZ-7F284-BA
This is optional it will soften the 1-2 shift most of us leave it out.
2-3 ACC...F7AZ-7H292-BA
2-3 SPR...F7AZ-7F285-AA
This is optional it will soften the 2-3 shift most of us leave it out.
Separator Gaskets F2VY-7C155-A
F5AZ-7D100-A
DEEP PAN F6AZ-7A194-A
DEEP FILTER F6AZ-7A098-A
I used 13 QTS of trans fluid and I have not installed a trans cooler. I would get 16QTS to be safe.
Hope this helps
Fuel man~~~
1 - 2 of 2 Posts
