I need to:
- add mounting for the housing
- replace lens with plexi painted only on reverse (no black).
- run wiring to gauge sensors and to dash lighting circuit
- buy (removeable) piggy-back mirror attachment to use while driving
I dunno how inspections are in your state.. but just to let you know, you might have a problem conforming to federal vehicle regulations without a driver's rear view mirror.. If you know a police officer or inspection station.. you might want to check with them before you start running around with that configuration.
I thought of it a while back but am just getting around to doing it. Just kind of hit me when I was actually looking at the forward facing side of the mirror housing. I'm not 100% on it yet, it doesn't look the way I invisioned yet so I have some more work to do. The gauge faces do read very nice from the drivers seat though.
[/url]
I'm not too worried about it. In MD we don't have to take our cars in for periodic safety tests. Instead the car gets inspected once everytime it is registered to the new owner. However, for my own peace of mind I don't plan on driving around without a mirror. Part of this project is to get one of those wide view piggy back mirrors that clips to the top of the existing mirror housing. I wil use that while actually driving so I retain full visibility and I can pop it off when parked.
why nhot use a mirrored plastic, kind of like they do on some cell phones where it's shiny and reflective, but when the little screen comes on it shines right through while maintaining the mirror aspect.
I don't want anything too reflective as it can reflect background images that might make it a little more difficult to read the gauge faces. I want to be able to glance at them and read them quickly without distraction. I will be changes the black background though. I don't like the contrast of the black face and the hardware. I will probably use silver paint on the final piece.
The main cluster is an SC set with a 200KPH speedo. and the boost gauge is only being used for vac readings.
The center console cluster is for actual boost, volts, and fuel pressure.
The mirror housing will be monitoring oil and cyl. head temps.
I was posting on here last week and researching all the things that could go wrong on this job. I can't say I was looking forward to it, but with the only alternitives likely to cost loads of cash with no guarantee of a good job, I decided to have a go.
I printed off the instructions here...
i what a 145 mph speedo for my 95 cougar what do i need to get it outta? a sc sho? i'am going to get a set of white face gauges to from scott to help please thanks
Hello all.. Need to pick the brains of the knowledge base here if i may. Just bought a 1989 and like most cars of the era if your 6'7" its a bit of a squeeze.. Has anyone successfully added "Seat Track Extenders" on their mn12? They are everywhere for mustangs and the do look like they would...
Im sure a few of you have done this so i am getting a tune from scp and he needs my computer code. He told me its behind the kick panel on passengers side. How do i get to it without breaking nothing?
We have owned this 1997 Cougar since new...no accidents, etc...
In the past year the drivers side window has shown rub marks (vertical) about the center of the glass and the window will operate fine, you can tell there is resistance. The passenger side window (which has little use) is...
