1 - 10 of 10 Posts
Hello all,
After selling my '97, I have some parts left over that I've finally decided to gather to sell. I have pictures attached but here is a list with prices. If you'd like to buy everything, I think $400 is a fair price.
PLEASE NOTE, buyers must pay shipping from 45431 (Beavercreek, OH) unless you'd like to pick anything up. For anyone wishing to pick anything up, reply in the thread first or follow forum rules, then proceed to message me for address information.
PLEASE NOTE, any [used] OEM parts have roughly 60k miles on them.
- 1996 center console (with toggle switch holes drilled in coin slots) - $20
- Radio console - $5
- SuperCoupe Performance CAI, ceramic coated black (Eastwood) - $75
- New Oil Pan gasket (2V) - $5
- New Oil Filter Adapter gasket (2V with no oil cooler; so 99% of you) - Free add-on item, must buy with something else
- New Oil Plug drain bolt - Free add-on item, must buy with something else
- Crankcase Vent crossover tube - Free add-on item, must buy with something else
- New Energy Suspension 1 1/6-inch PU front sway bar bushings and brackets (9.5169R) - $12
- New Fram oil filter - Free add-on item, must buy with something else
- OEM Chassis/Exhaust guard brace - $15
- Replacement heater hose (88396) - $5
- New Moog Rear LCA to Subframe bushings - $10
- OEM Rear end links with poly bushings with stock brackets, with misc. bolts, studs, washers for upgrading to ES poly bushings with bigger sway bar - $5
- 4-inch MAF adapter (3.5-inch-sq bolt pattern) - Free add-on item, must buy with something else
- OEM trigger wheel - $10
- OEM crank gears - $5
- New Viton valve stem seals (PI and NPI) - $20
- [SOLD] Custom COP conversion kit with Motorcraft coils (true plug and play; clean up that engine bay) - $100
- New dual pattern (5x4.25/5x4.5) Amico 13" front brake rotors (from discbrakesrus.com) - $80
NOT PICTURED (reply with request for pictures):
- Assembled NPI heads (with OEM valvetrain and stock cams); were removed as part of engine build - $150
- OEM Torque Converter; swapped as part of drivetrain build - $40
- ADDCO 1 3/8-inch front sway bar; never used but shop tried to install, either techs were really stupid or the subframe will need notched - $125
Thanks, Eric
Drae, sorry it took me all weekend to respond. I've had a few responses on the COP conversion harness, but you're first in line.
The whole kit is about 5 pounds, and I'd ship UPS in whatever packaging the buyer would like, so you'll have to calculate shipping on your end, sorry.
For the other few who've inquired about the COP kit, I will follow-up in the order everyone responded, thanks.
- Eric
Damn I'm glad I was first. I PMed you about it. I'm not letting this kit go. Perfect timing for the new to me PI motor.
I just caught the Yorkie reply, lol well played. He comes with food, supply your own water.
I'm adding another picture of the headlamp and corner lamp as requested via a private message. The corner lamp is very clear; I swapped them for a set of clear corners. The headlamps were swapped for newer but just before were sanded and polished, then clear coated with UV clear, so I'm not sure how much of the haze is due to the clear and how much is due to old age, but they don't look bad for $15 total.
I'm also adding a pair of DEA #A2995 Hydraulic Motor Mounts (4.6 2V), never used,that I forgot I had. I will sell the pair for $40 in a flat rate USPS box.
Additional Items for Sale
The rear UCA to knuckle bushings and bump stops have been sold.
ALSO FOR SALE (Pictures upon request):
- 1.5 sets (I lost half a set...) of Stage 8 Locking Header Bolts, never used - $30
- PI Alternator (PI or NPI Intake to PI Alternator) bracket - $10
- Set of 4 Cragar S/S FWD 17x7 (5x4.25/5x4.5 dual pattern; +40 offset); currently Plasti-dipped black but were ceramic-painted black, but original color was I believe charcoal - HOWEVER - one wheel is severely damaged on lip, and I doubt it's repairable - $150 PICK UP ONLY (45431) - again, pictures upon request
1 - 10 of 10 Posts
