If you could please get some prices on some more parts for me, I'd greatly appreciate it! They're all for a 1997 Ford Thunderbird LX with a 4.6 liter V-8; I have provided Motorcraft numbers where available (just because I provided Motorcraft numbers doesn't mean they HAVE to be Motorcraft, whatever's least expensive):
Front (upstream) O2 sensors (DY761)
Rear (downstream) O2 sensors (DY1086)
EGR valve (CX1920)
EGR valve gasket (CG682)
EGR pressure feedback sensor
EGR vacuum solenoid
Throttle position sensor (DY967)
Thermostat o-ring/gasket (RG571)
Ignition coil (DG523)
Spark-plug wire set (WR5935)
Fuel injector (CM4809)
O-rings for 8 injectors
Fuel pressure regulator (CM4760)
Thank you very much, sir!
Johnny Bling Bling
Vin?
I'm sorry - VIN is as follows:
1FALP62W2VH131734
Build date: 01/97
Thank you!
Johnny Bling Bling
in order:
52.90
58.19
54.00
2.12
73.01
22.79
30.59
3.42
92.05
38.76
55.42
12.66
55.93
Thank you, sir! I'll be contacting you, I'm sure, in the near future to order some of these parts.
