1 - 1 of 1 Posts
Disconnect drive bolt from pump pulley. Remove 4 bolts and remove pump and pulley. To install pump, reverse removal procedure. Refill and bleed hydraulic system.
That's the R&I procedure for a 96 Cougar power steering pump. It might as well say:
Remove pump. To install, reverse procedure.
Has anyone else had the unfortunate luck to encounter Mitchell/Shopkey? Or am I the only one that hates it?
1 - 1 of 1 Posts
