:confused:My daughters 1998 MK VIII has sprung an oil leak. Looks to be from the front engine seal/vibration dampener seal. Does anyone know if this seal is replaceable from the front, whereas I just have to remove the vibration dampener & replace the seal? OR, do I have to dis-assemble the entire front end of engine & remove the timing chain cover to replace the seal. Just trying to get an idea of the job ahead of me & how long I'll have the car down to repair. Any help will be appreciated. Thank you in advanced.
Pretty sure you don't have to remove the cover, to replace the front seal.
Remove crank bolt and washer
Remove the dampener
R&R the seal, re-install dampener(use RTV on the key/keyway)
Install new crank bolt(stock is TTY and one-use only)
IF it is indeed the front seal, yes it can be replaced in the car...
Oil Seal, Front
Tools Required:
~ Crankshaft Damper Remover T58P-6316-D
~ Crankshaft Damper Replacer T74P-6316-B
~ Front Cover Seal Remover T74P-6700-A
~ Plate T88T-6701-A2
~ Crankshaft Seal Installer/Cover Aligner T88T-6701-A
Removal
1. Disconnect negative battery cable.
2. Release belt tensioner and remove accessory drive belt. Refer to «Section 03-05».
3. Raise vehicle on a hoist. Refer to «Section 00-02».
4. Remove crankshaft damper retaining bolt and washer from crankshaft.
5. Install Crankshaft Damper Remover T58P-6316-D on damper and pull damper from crankshaft.
6. Using Front Cover Seal Remover T74P-6700-A, remove front cover seal.
Installation
1. Lubricate seal bore in front cover and seal lip with clean engine oil.
2. Using Crankshaft Damper Replacer T74P-6316-B and Plate T88T-6701-A2, install front cover seal.
3. Apply Silicone Gasket and Sealant F1AZ-19562-A (WSE-M4G323-A1) or equivalent in keyway of damper as shown.
4. Using Crankshaft Damper Replacer T74P-6316-B or equivalent, install crankshaft damper.
NOTE:
Ensure key on crankshaft aligns with keyway of damper.
5. Install crankshaft damper retaining bolt and washer. Tighten to 155-165 N-m (114-121 lb-ft).
6. Lower vehicle.
7. Install accessory drive belt. If necessary refer to «Section 03-05».
8. Connect negative battery cable.
9. Start engine and check for leaks.
The most common leak however is the oil filter adapter gasket.
Thank you! I wondered about the oil filter adapter, but wet oil around & below the vibration dampener & all over the passenger strut bushing (which was brand new 11 months ago) & K member. Everything is soooo packed in there, it is really hard to determine EXACTLY where the oil is coming from. It is definitely from the front of the engine though.
I'm going to go ahead & replace the oil filter adapter gasket while I'm down there. Anyone know the torque values to re-attach the oil filter adapter? Also, what is the gadget that looks like a little canister that is mounted REALLY close to the center of the vibration dampener? It has a black rubber hose (approx. 1" in diameter) attached to one end. Of course I have to move it out of the way to remove the vibration dampener, just wondering what the heck that thing is & what it does. Thanks again.
From the manual...
Tighten to 20 N-m (15 Lb-Ft) then tighten an additional 60 degrees
That would be the Secondary Air-Injection Diverter Valve. An emission control device used to direct air from the Secondary Air-Injection Pump to the exhaust manifolds.
