Status
Not open for further replies.
1 - 1 of 2 Posts
MN12 Performance Intercooler
Fan Kit 89-93 SC
Part#
ICFK100
stock intercooler fan kit 89-93 SC
Part#
ICFK200
stock intercooler fan kit 94-95 SC
Thank you for purchasing your MN12 Performance Intercooler Fan
Kit designed for the 1989-1993 Thunderbird/Cougar SC. The kit comes with
all the needed hardware and instructions to install the fan kit with no
special tools required. This fan kit is designed to turn the fan on when
the ignition is turned ON. Intercooler temps can be reduced by as much
as 30 degrees F. Installation time is about 1-2 hours.
Installation Instructions
Disconnect the battery and remove it from the car. Remove the black
rubber stone guard from the underside of the front cross member. Remove
the radiator support bolts, drain the radiator and remove the upper radiator
hose so the radiator fan may be removed from the car. Disconnect the transmission
lines (automatics only) from the radiator and tie them up (while
removing the radiator is not mandatory it makes for an easier installation
With radiator and battery removed position the fan on the backside of the
intercooler about 3 inches from the top with the fan wiring located at
the top. Insert the rubber washers over the nails and insert them through
the Intercooler with the top nails installed first. Using the supplied
Push Pins secure the fan to the Intercooler (see picture)
Using the wiring kit supplied attach the three black wires (ground)
to the headlight ground location (see picture).
Next using a 1/8 inch drill bit drill a hole approximately 2.5" inches
from the radiator support bolt for mounting the relay. (see picture)
Next locate the ignition wire (R/LG) (red with a light green stripe)
in the Fuse box wiring harness. Their are two (R/LG) ignition wires one
is a 10 guage wire and the other is a 14 guage wire. Next, disconnect the
Power Distribution Box (PDB) from it's support by using a small screw driver
to depress the 3 locking tabs that hold it to the metal support. With the
PDB disconnected from the bracket trim the wiring harness insulation back
about 2 inches to allow enough slack for the tap to be installed on the
14 guage (R/LG) wire. Next unscrew the lower nut that holds the 175amp
Megafuse and install the RED 12v power connection.
Install the 3M 901 tap supplied on the ignition wire (R/LG).
Connect the wiring harness to the thermostat switch if not already.
WIRE
CONNECTION
RELAY
RED
+12volts
30
YELLOW
Ignition Coil
85
BLACK
Ground
86
ORANGE
Fan
87
Reinstall the radiator, fan, and battery. Fill the radiator start the
car and check all connections.
Hardware:
1
30amp Relay
1
3M 901 Tap
1
Wiring harness
4
Fan support nails
1
Fan
Comments/Questions:
MN12 Performance Inc.
(703) 968-6513
1 - 1 of 2 Posts
Status
