Does anyone have the part numbers for new bushings for the upper and lower arms on the rear? :2huh:
I already have poly's for the knuckle, and I'd like poly's for the inners, but I don't think they are available. So I'll be forced to go back with OEM.
Here's what I see in the MOOG catalogue in front of me ...
Upper arm, to frame K8562
Upper arm, to knuckle K8588
2 kits required per car
Lower arm, bushing kit K8568
Lower arm, cam bolt kit K8522
cheers,
Ed N.
the arm bushings might not be poly. I got a set of Moog front UCA bushings and they were rubber:( Then again, I am not right from time to time.
joseph
Yeah, the Moog parts are OEM (or slightly better maybe) or so I've been told. :(
The Poly's aren't available anywhere to my knowledge, but I want at least new, not 266K miles like I have on mine now. :eek:
fast Ed N: Thanks very much for the part numbers!! :thumbsup:
Can someone double-check these numbers?
On Rockauto, I'm coming up with a slightly different number for the lower arm to frame bushing:
K8658 vs. K8568
Unfortunately, they are both legitimate part numbers. :2huh:
I think the correct number is: K8658 (Moog or Spicer; Rr Susp; Lower; To Frame; 2 required; Control Arm Bushing)
The order is going in soon and I don’t want to get the wrong part. :(
Thanks. :thumbsup:
Your eyes are playing tricks on you. :beek:
I couldn't find K8568. I think you mean K8562.
Upper rear arm to frame: K8562
Lower rear arm to frame: K8658
Sources: RockAuto and the Moog part look-up the Federal-Mogul web site
