121 - 140 of 808 Posts
just a lil update.....still welding seams, and tinkering with the new h/c/i.
thats all for now!
Thats a LOT of seams .. but a very good idea that I have considered doing to my own ride. Ive noticed that even the Mark 8's got a few little welded seams in a couple areas ... shock towers rings for example, something the Tbird did not get.
you got heads now?!
yep, nothing major though....just some first gen lightning heads.
tell me about it......I haven't done this much welding in a long time!!
Fvcking fires.... :p
Discussion Starter #124
I know why the right side wasn't cathing on fire like the left......I didn't weld up 1 seam on the right side like I did on the left.....sooooo, I need you to come by again today and watch that side so I don't have to keep getting out and putting the fire out.
btw, I got the roof all welded up too, along with the dash....I finally started on the back end.
And I also started grinding in the front wheel well.
Sweet... Hey I replied to the AJL thread in the Pic of the "who-cares" thread....
I need to go talk to Hal tonight..... ;)
SuperNewbie
Whats your goal for doing all the seam welding? Strength? Noise? Just curious.
Forgot to add, I'm about to drop the whole rear assembly as well.....its about to be a shell.
strength mostly.....most of the interior welding will be dressed up to look better.
Go get you some disposable diapers, use the stuff inside to make a paste. Really cuts down on the fires and what areas get scorched and burned. Protects paint pretty well on surrounding areas too.
Discussion Starter #132
:leftright
Discussion Starter #134
More than likely....I would like to find some aluminum rear lowers as well.....maybe even an aluminum pumpkin...
:leftright
I'm serious.
I made me some a while back to protect some areas where I was using a flame and it kept all the paint underneath nice and purdy.
Discussion Starter #136
I'm serious.
I know you were :D
I haven't needed that yet though....but I will keep it in mind......
.....what was cathing on fire was the foam crap that is still in the fenderwells...that sh1t stinks when it burns!
SuperNewbie
Im getting ready to weld and detail my subframe and K member. I already have the aluminum pumpkin. I haven't bought the LCA's yet, though I do have the spring perches on the shelf for them.
Discussion Starter #138
cool.....maybe you can send me some dimensions of those perches....should be easy enough to make..
