1 - 10 of 10 Posts
  • So a guy says he has a early thunderbird motor. From alternator location it is a modular motor.. How can I tell if it's a 94&95 motor or a 96&97 one and are they interchangeable. Thanks a bunch for any info.
1994 Cougar XR7 DOHC/5-Speed
Obvious = 96-97 uses a plastic intake with the throttle body in the center facing sideways, 94-95 uses an aluminum intake manifold with the throttle body in the rear facing forward. Not so obvious = there arent side bolts in the side of the block for the 5h main cap on 94-95s and 94-95 heads will have a F4 prefix at the start of the part number, 96-97 will have F5.
Avoid the 94-95 one like the plague.
Discussion Starter · #3 ·
Even if it's for 200 dollars and I may use it as more of a learning motor. Or rebuild it with more of attention to the small details I have always heard the early the 4.6 the more fragile they are and this one does look like it has a straight throttle intake.
You might want to search to see if the 02 PI engine used the really crappy timing chain guides that broke to pieces and trashed engines.
The 03 PI engine I had did; the clue is the Plastic tensioners.
1 - 10 of 10 Posts
