i did a search but didn't come up with what i was looking for, but if this was answered before could some one send me the link to the thread. ok, here is the question, do they make solid metal motor mounts for the 4.6 t-bird? if so, could someone tell me where i could buy some.
thanks
johnny langton used to make solid metal motor mounts.
i have a set of 2 on the car now. they are a bit to get used to in a daily driver. vibrations definately are felt.
you'll have to delete the 'change in the ashtray' mod after you gets solid mounts.
i'd recommend either stock or solid rubber if i had to do it again.
Yeah, mine vibrates pretty bad at hot idle in gear with just the solid drivers mount. Anyway, I made my solid mount for free. Just cut a piece of exhaust pipe to the length you need, buy a bolt long enough to go through the brackets and pipe. Then you get it all lined up and tighten it down. Threadlocker isnt a bad idea here. Just an idea for ya!
-Rob
Thanks for the info it will help me with my decisions.
