I have a 96 tbird lx 3.8l and The motor is a used one i got from a wrecking yard in southern cali cause the original messed up and the guy said it had 70,000 miles on it but seems like the oil is going somewhere i guess being burnt somehow cause theres no leaks at all and the car runs very good and strong and no smoke from the muffler.
Any one know what should i use i;m been using 10-30 and like every month i check the oil it needs about or almost half a quart. my girl does drive it on the freeway to work where it about 30 miles to work. any additives or something.
oil burns naturally just from the engine running, since it coats the cylinder walls when the cylinder combusts it's going to burn off a very slight amount of oil. half a quart over a months time isn't all that bad, though you could try putting some seafoam in the oil and see if that helps. You can also try a compression check to see if the oil seals are gone. It could also possibly be leaking valve stem seals. It's just hard to say.
-Thomas
-Thomas
Ok cool is there some additives to seal those seals better? And what seafoam i buy and how do i use it?
it's just seafoam, it's only one kind. Well, there's also the seafom TransTune but that's obviously only for transmissions. Just dump 1/2 a can of it into your oil fill hole and if you want you can put the rest in your gas, or put the rest in the engine through a vacuum tube.
-Thomas
