I know it has been asked b4.
I think i figured out how to mount the bottom peices
But the peices on the door have me stumped.
How is the best and esiest way to mount the door things?
I have alot of 3m two sided tape if that helps.
Do you have the mounting hardware for the doors? I have never tried this, but I would think if you riveted the mounting hardware onto the door and snapped the gfx piece over them, it would probably the best way to do it.
I have just pulled the door pieces off a SC a few weeks ago, so the info is still fresh in my mind:
There are about 6-8 plastic pieces that hold/support the metal trim piece on the door, and each of those plastic pieces is slid over a metal protrusion. Simply pop riviting these pieces to the door will work - and that's how I'll be doing it.
Each door trim piece also has 2 'bolts', one on each end, they go through holes in the door, and are 'nutted' on the other side.
How do you plan on mounting the plastic pieces for the sides? I ask this cause I could always use a new suggestion :).
