1 - 13 of 13 Posts
I have a '96 4.6L and I want the red MSD spark plug wires for my car. I'm not sure which ones will fit my Bird though.
This one says: Ford/Lincoln, Mustang/Mark VIII, Set. But SOHC only. But it doesn't say anything about a V8
http://store.summitracing.com/default.asp?target=esearch.asp&N=110&Ntk=KeywordSearch&Ntt=MSD+Spark+Plug+Wires+Ford+V8
This one says: 4.6 Mustang. But it says DOHC
I'm not even sure if either of these are right. Someone please help me find what I'm looking for, thanks.
think about it....if they say they will fit a SOHC mustang, does that SOHC mustang have a V8?
if you said yes to the question, then your problem is solved and you found the answer.
joseph
The Mark VIII has a DOHC, so wouldn't the same wires that fit the Cobra fit the Mark VIII? and if thats the case, shouldn't it say:
"Ford, Mustang, set SOHC" or "Cobra/Mark VIII DOHC" or something to that effect?
Anyway the answer to your question is whatever set is made for the Mustang GT 4.6 SOHC (non-Cobra) will also fit your T-bird.
Part number FMS-M-12259-R462
Ford RAcing wires have fitament issues. Id get some moroso bluemax spiral core wires from jegs.com. They r 8mm, and fit in the stock wire holders. They fit perfectly.
I don't want blue wires because I have a red car. I know the stock wires are 8mm the MSD are 8.5mm and the Ford Racing are 9mm. What are the different sizes for? Do I need a certain size?
I have heard that Motorcraft wires are just as good :D
1 - 13 of 13 Posts
