yes, but you will have to swap the shifter linkages.
John
the part on the transmission that the shifter cable attaches to. It is different on a mustang.
John
Yes, the only thing you gotta change is the linkage, and it is a direct bolt on.
Be sure to get the compression pin out when your swaping the linkage.....we didnt and now the old tranny from the bird is in need of more repair......Go with the mustang AOD it is just as good.
Actually an SC trans is better. It has the A servo, where as the Mustang trans only has a B servo, like ours come from the factory with.
John
High Output Poster
John
What he said.:thumbsup:
what is the purpose of a compression pin, and thanks a lot guys you are the best!
