I almost ran it out of gas, I was on the corronado bridge in rush hour. It died then I started it and repeated several times. Finally I got to the gas station that had a huge line. I smelled rotten aggs the gas gauge is another thing that doesn't work on the car. The voltage gauge dips violently then the car bogs down horribly then the car starts to jerk and sputter. No codes at all. What could be the cause?
probably sucked something up against the sock on the fuel pump and it isnt getting enough gas to the motor. had a truck do that to me after i ran it out of gas. i let it set about a day and started it up and it ran fine.
jmo
if you are at home and have a different ride, i would let it set for a day and settle out, try it tomorrow and *should* be ok. (crosses fingers)
