1 - 20 of 36 Posts
93 cougar the ride in this car sucks allways has.when I first got it replaced front struts and rear shocks ride was better but still sucks! if I drive over a speed bumb like in a shopping center it rocks side to side so hard Ive hit my head on the drivers window! so I need input on this prob. I was thinking front and rear sway bar bushings.
Did you change the springs also?
No I had a shop do the front shocks,I did the rears. the up and down shock dampening works fine on the car its the side to side movement that harsh.I guess if the coils were worn out it could cause the prob but I think its something else like worn out bushings like stabilizer bar links frt & rear. when I bounce front or rear bumpers car bounces once if springs or shocks are bad I would have 2 or 3 bounces that's what I've always been told.After reading thru some posts here other owners have the same problems and end up replacing everything I don't want to spend to much on this car.just fix the side to side movement .oh I do have a clunking sound from rear suspension
Well the only way to see first hand is to get under the car and inspect the bushings. I know you don't want to spend a lot but any shot bushings need to be replaced.
I'm with Joe on this one though, your springs are old and worn out. if your other bushings are shot enough to make it rock like that then you probably need to replace a lot of them. Check the sway bar bushings would be a good start.
Thanks for input guys! this is my sons car .I used to drive it 3 or 4 years ago it wasant as bad then but now its a nasty ride.last time I checked the bumper bounce technique was 6 months ago.my bad sorry! I just went and checked it again and the front is defiantly bad 3 bounces and lots of side to side! so the shocks are shot I guess.they were replaced about 5 years ago or 15k miles .I think they were Monroe and I'm looking for the receipt to see what kind of warranty they have . the rear are still good
Prob one shock totally shot for that side-side in the front. Stiill doesnt account for violent side to side, sway bar links are usual cause of that. Points to a broken link, as does the 'clunk in the back'.
Here's some pic's of front suspension
<a href="http://s580.photobucket.com/albums/ss244/1956pack/?action=view&current=IMG_0706.jpg" target="_blank"><img src="http://i580.photobucket.com/albums/ss244/1956pack/IMG_0706.jpg" border="0" alt="Photobucket"></a>
<a href="http://s580.photobucket.com/albums/ss244/1956pack/?action=view&current=IMG_0708.jpg" target="_blank"><img src="http://i580.photobucket.com/albums/ss244/1956pack/IMG_0708.jpg" border="0" alt="Photobucket"></a>
<a href="http://s580.photobucket.com/albums/ss244/1956pack/?action=view&current=IMG_0701.jpg" target="_blank"><img src="http://i580.photobucket.com/albums/ss244/1956pack/IMG_0701.jpg" border="0" alt="Photobucket"></a>
<a href="http://s580.photobucket.com/albums/ss244/1956pack/?action=view&current=IMG_0704.jpg" target="_blank"><img src="http://i580.photobucket.com/albums/ss244/1956pack/IMG_0704.jpg" border="0" alt="Photobucket"></a>
<a href="http://s580.photobucket.com/albums/ss244/1956pack/?action=view&current=IMG_0710.jpg" target="_blank"><img src="http://i580.photobucket.com/albums/ss244/1956pack/IMG_0710.jpg" border="0" alt="front coil D side"></a>
<a href="http://s580.photobucket.com/albums/ss244/1956pack/?action=view&current=IMG_0700.jpg" target="_blank"><img src="http://i580.photobucket.com/albums/ss244/1956pack/IMG_0700.jpg" border="0" alt="Photobucket"></a>
<a href="http://s580.photobucket.com/albums/ss244/1956pack/?action=view&current=IMG_0705.jpg" target="_blank"><img src="http://i580.photobucket.com/albums/ss244/1956pack/IMG_0705.jpg" border="0" alt="Photobucket"></a>
<a href="http://s580.photobucket.com/albums/ss244/1956pack/?action=view&current=IMG_0703.jpg" target="_blank"><img src="http://i580.photobucket.com/albums/ss244/1956pack/IMG_0703.jpg" border="0" alt="Photobucket"></a>
<a href="http://s580.photobucket.com/albums/ss244/1956pack/?action=view&current=IMG_0707.jpg" target="_blank"><img src="http://i580.photobucket.com/albums/ss244/1956pack/IMG_0707.jpg" border="0" alt="Photobucket"></a>
UCA bushings need to be replaced, LCAs arent too bad but should be done in the next couple of years. Sway bar bushings arent too bad either, but you should get new end links. Yours looks better than my '89 did when I rebuilt it last year.
UCAs and and sway bar end links are pretty easy to do. I recommend Moog suspension parts. :)
Good luck.
Agree with the UCA's and end links. Problem with having worn out/bad suspension parts mixed with good parts is the worn out parts cause the good parts to wear out faster. It's best to have everything in good shape.
Good point, I kind of had to do everything at once since it all looked like crap, but if the OP is short on money the UCAs and end links are definitely first.
The UCA looks totally torn. We noticed this in our lemons tbird and under acceleration, we'd hear a serious "thunk". Good news is rockauto sells the Dormans as an entire upper control arm with bushing for only ~$20.
You might also want to check to see if your motor mount was blown. That was the source of the second "thunking" sound we found in the car. If your motor rocks significantly when you put it in drive, give it revs, and hold the brake, you likely have a blown MM.
-g
Yes those are the obvious ones.
Check Rock Auto like Gunn said, you can get UCA's and front end links shipped to your front door for $85 or so depending on what brands you get. You should check the rear sway bar end links too. When you have the tires off look at everything and you don't have to replace everything right now but keep in mind what needs to be done next.
Found these on Amazon comp units.can I do this myself in the driveway?I've got 2 floor jacks,jack stands,air commpressor, with air tools.how hard is this to do? I dont think I have to mess with the compressing the spring since its all put together right?
Monroe 171845L Quick-Strut Complete Strut Assembly
http://www.amazon.com/Monroe-171845L-Quick-Strut-Complete-Assembly/dp/B000C59KHM/ref=au_pf_pfg_s?ie=UTF8&Model=Cougar|720&n=15684181&s=automotive&Make=Mercury|56&Year=1993|1993&newCar=1&carId=001
<a href="http://s580.photobucket.com/albums/ss244/1956pack/?action=view&current=s.jpg" target="_blank"><img src="http://i580.photobucket.com/albums/ss244/1956pack/s.jpg" border="0" alt="Photobucket"></a>
Personally I went with the Motorcraft arms. They were the most expensive but that's my preference.
As long as the spring is installed on the strut it shouldn't be too bad. But seriously, if you just change the shocks and don't fix anything else the shocks won't last long.
Easy with the tools that you have. Thats all I used. :)
Just knock the bolt out of the LCA, let everything drop, and unscrew the three little screws on the top. The Monroes arent too bad for a middle of the road shock, thats what mine had when I bought it. :)
The bad news is it won't last a week.
Yeah, spend twice as much for the Moog and have it last 10x longer. :)
Hate to disappoint you but both sides have lasted a bit longer than that already.
It lasted for 3 solid on the Thunderhill track without any problems. Between driving to/from the track + commutes to/from my storage garage (~50mi from my house each way), I've put several weeks if not months of equivalent DD driving.
This is NOT a part I would pass on to my kids as a "as a family heirloom"; I hate to break it to you but a tbird isn't that kind of car as well.
This is a tool and the Dorman part is perfectly serviceable for a great price (I mean literally servicable, too. These are grease fittings on the top of the upper ball joints).
-g
If you have one near you, Autozone rents spring compressors for free. I've used these several times as we were adjusting our front shocks/springs.
http://www.autozone.com/autozone/accessories/Tools-Garage-and-Equipment/Strut-Spring-Compressor/_/N-25f9?filterByKeyWord=spring+compressor&fromString=search
Once you have the car jacked up and the wheel off, here's a time that will make the process go much more quickly.
1) Attach the spring compressors to the spring as best you can. Make sure they are balanced (on opposite sides)
2) Knock off the bolt holding the UCA onto the knuckle.
3) Use a second jack to compress the knuckle. This will also compress the spring.
4) Tighten the spring compressors.
5) Lower the jack that is compressing the knuckle. the spring compressors, if they are short enough, should relieve the pressure the spring is exerting on the knuckle.
6) When you remove the top 3 bolts and the bottom bolt holding the strut assembly to the knuckle, you should be able to lift the whole assembly out w/o any fuss.
Also, watch out that you are NOT unduly stressing your front brake lines. I was worried we were gonna snap our SS lines a few times.
-g
1994 Cougar XR7 DOHC/5-Speed
Hate to disagree but considering the track record of actual daily driving (a smooth race track isn't that) the elcheapo junk tends to have a failure rate of ~6 months. I in all good conscience would never recommend something like that on a street car.
Oh and thanks for breaking it to me:rolleyes: I forgot family heirlooms these days were ****ty Hondas/Acuras.
Do NOT, I repeat, do NOT use spring compressors on the front springs! You do not need to compress the springs to remove the coilover assembly! There's never any need to compress those springs unless you're removing the spring from the shock, but use a wall compressor for that.
Get the wheel in the air and get the tire off. Unbolt and remove the pinch bolt at the upper control arm to spindle. I find these can be stubborn; once the nut is off soak it in blaster, then use a crescent wrench on the head of the bolt to rock it back and forth until you can knock it out with a hammer.
Next get the upper ball joint out of the spindle. Most of the time it goes without much fuss with a big whack to the UCA with a good sized sledge, but in the event it doesn't, I've used these to help coax them along:
Once the upper ball joint is out of the spindle, the lower control arm will drop a bit as the shock is fully extended by the spring. Next you have to get the bolt out at the bottom of the shock. This can be a royal pain or it can be a breeze. I didn't bother with it the last time I did work; I removed the coilovers with the LCAs as a unit since the LCAs were being replaced anyway. Might not be a bad idea for you either, if they ball joints aren't shot yet they will be soon. Not to mention the strut rod bushings.
Then out come the three nuts at the top of the shock tower in the engine bay, and it'll slide right out.
1 - 20 of 36 Posts
