1 - 20 of 25 Posts
as the title says. my car is having a problem when i go to start it, everything works the fuel pump goes but just nothng happens when i turn the key all the way. i dont have a multimeter so i can't see if its the battery, but i dont thnk it can be that because everything in my car can work, even my stereo system. im just lost and fed up with my car :mad:
Do you hear any clicks or anything? If the battery is good, it's probably the starter / solenoid combo that's gone bad. Also, check your fuses and everything pertaining to the starter.
Pete
I second that it may be the solenoid. U can hit it and it might help for a short time and if u really need to get somewhere u can jump it with a screwdriver.
razzibird said:
is the selenoid clicking or even making noise?
not at all. when i turn the key all the way the only thing that happens is the volt meter drops quite a bit, and things dim a little bit. im hopein on my battery, checkin that out tomorrow
sounds like the solenoid. . . . .I would hit it with a rubber mallet and see if it works after that. If so, then it is the solenoid/starter. => Replace starter.
You should be able to start it with a screwdriver...
Turn the key on, while on jackstands, and short the solenoid wire to the main hot wire with a screwdriver... I used to start my old tbird like that for a while, while I was a broke high school student...
If it will start, you have a problem with the main key switch; its on the lower part of the steering column, as I recall.
You can add a bypass switch into the harness, and wait untill something else goes out; it makes it more theftproof...only you know where the starter is.
Don't make the same mistake I did. Check the ignition switch FIRST. It's a $17 part that takes 10 min. to change. Mine was heavily worn and burnt from arcing when I dissected it.
i think i found out my problem, i guess in the engine swap the guys that did it didnt connect the passenger side ground. i can see it its hanging like right below the ac pully still attached to the block, i had my brother hold it to the k-member and i tryhed starting it but still the same old thing happened. Is there a new place i can make up a passenger side ground?
looks like the battery is dead... anyone wanna bet??? :p
Discussion Starter #14
its not the battery i hooked up a pair of jumpers today to a friends car. im placing my bet on the igniton start switch I HOPE. im gonna jack it up tomorrow and try jumping the 2 posts on the starter if it cranks it should be the switch then, right?
Go for it. Just remeber play it safe
No, the solenoid could still be bad. All this does is short across the solenoid taking it out of the circuit.
Discussion Starter #18
woww im really ****t now, i did the jump thing and the engine started up! i didn't have a belt on and rad hoses conencted so i quickly shut it off. i hook up everything and go to jump the 2 posts agin and the frigin thing sounds like its not engaging the starter motor is just spinnin its *** off. what the hell do i do now? im about to call the junkers and take the 1100$ hit
If it sounds like the starter is just spinning, then the starter is definately bad. . . .this is the bendix (sp?) being bad. Replace the starter and you should be good to go! :thumbsup:
BTW. . .it sounds like the solenoid may not have been the complete problem with the starter. . . .
1 - 20 of 25 Posts
