Not for long, it will start to peel in a few months.Josh Heilig said:that looks awesome
the new ones are alot better. i had a set of his original ones, they peeled in a couple months. ive got the new ones now and they are great.GreenBird said:
Yes...bad as in good. What did u have to do to get that setup?Alex said:Bad as in good?![]()
No, I mounted the gauges in front of the cluster. I have the older style interior so if you know what I'm talking about, I put them to the right and left of the mound that comes up from the steering wheel.ShadowDragon said:
Oh, and you put the neons behind the guages? Cause I can't see the tubes. Looks very clean.
The needles might change color, won't get rid of the green though...mikes97 said:Are the white gauge faces that Geno is selling having a problem with peeling? Has anyone tried just colored bulbs behind the stock faces? If so, how does it look?
