Aaron_T said:All that means is you HAVE to go to the track again this year![]()
I had that same problem in 01', running 15.0's. Kind of sucks, but atleast you know it should be able to get a 14.
What type of tires are you running? Looks like some sort of drag radial based on 2.1 60fts.
Good luck![]()
Mind sharing your mods and what not to other fellow 96/97ers?fdawg97lx said:damn 15.0's. i've been stuck at 15.008 since last october. only been to the track once this year though. with the stuff i got goin in the bird in the next couple of weeks, i'm hoping to just skip 14's all together.
Frank
ITT-BIRD said:
Tires ... what tires? You must mean those 3mm thick rubber bands i have back there?Drag radials, farest thing from it, i do launch at 1800rpm. Just some wore out, el cheapo 225/60/16 street tires. Im pretty sure once if the temp/humidity was better, better tires, true duals, and definitely a SCT chip, id be well into the high 14s. But i definitely cant afford any of that right now. So once the temps drop im hoping to break 14s. Im just glad im running consistant, minus the first few runs that i didnt go aroudn the water trap.
Thanks for the motivation guys.scottkornhaus said:Or you could be like me, and just remove your back seat and passenger seat. That will get you to the 14's!!!![]()
-Kornhaus
Whole motor... '02 exploder.Jack K said:He doesn't need drag radials. He's cutting 2.1's on street tires, so he's obviously hooking up. For 90.5 - 91.5mph, the 1/4 time is right where it should be.
What do you mean by PI powered? Intake...Cams.... Heads? Or whole motor?
