Are they hub centric rings? Mustang hubs are a different circumference, IMRC
Now that I've mentioned this, I will have to say that the suspension will most definitely take me a long time to get it to where I want it to be at. The rear hubs being replaced is basically my starting point on all this. I'm going to be doing more reading and research on the matter, and of course asking here as questions from me come along.Lovely Chinese wheel bearings....
The hub bore of the Mustang is larger than the T-bird. If you use the Mustang Cobra rear hubs (or the FTBR hubs), then the center bore of the rotor matches the center bore of the hub and the rings are not needed. If you re-drill your stock T-bird hubs to the Mustang bolt pattern (or redrill the Cobra rotors to the T-bird bolt pattern) then the rings take up that difference to center the Mustang rotor on the T-bird hub.Looking at the rear brake relocation kit from Super Coupes Unlimited, I see one kit has rings and the other kit does not have rings.
What is the purpose of the rings?
So as long as I do a hub swap, I don't need to worry about getting the rings, right?The hub bore of the Mustang is larger than the T-bird. If you use the Mustang Cobra rear hubs (or the FTBR hubs), then the center bore of the rotor matches the center bore of the hub and the rings are not needed. If you re-drill your stock T-bird hubs to the Mustang bolt pattern (or redrill the Cobra rotors to the T-bird bolt pattern) then the rings take up that difference to center the Mustang rotor on the T-bird hub.
Right.So as long as I do a hub swap, I don't need to worry about getting the rings, right?
The part number won’t tell you anything about the program on it, the catch code is what you should look for; ggl4, zxa3, zxa4 are all 96-97 GT 5-speed codes. There may be more but those seem to be the most commonWhat's the PN for the 96/97 SN95 Manual ECU?
I think I'll look for one on the fleabay. I'm going to chance it.
My wife would flip if it sat for that long. Shoot, the 5yrs or so it's already sat has been bad enough.Hey, you're getting there. These things can take time, but you have to keep your eye on the prize. My car sat for 14 years before I had the funds to do anything with it.
I was lucky enough to have a building at my parent's place where it was out of the way. If I had to store it, you likely wouldn't see me here.My wife would flip if it sat for that long. Shoot, the 5yrs or so it's already sat has been bad enough.
