1 - 2 of 2 Posts
MaleWhore
well...i locked my doors this morning...and a few seconds later...as im like 30 feet away from my car...my alarm started going off...my thought is that since it takes a few seconds for my alarm to engage...and if a door is open, it will go off. my doors were closed...but im thinking my car thinks one is open...so my question is..how do i fix it...now that i tried it again...like an hour later...it doesnt do it anymore...my temporary fix was to leave the doors unlocked...:confused:
if you have the factory keyless entry like me, open up the door panels and look for a gray plastic connector under the door lock. On my pass. side the connector was unplugged and looked crunched, I re-connected it and it hasn't gone off since. If everything is connected, wd-40 the area around the door locks. If your door ajar light is on 24/7 than its a switch/wiring issue right around the door lock, usually the int. light pin is fine and isn't the problem.
1 - 2 of 2 Posts
