1 - 10 of 10 Posts
Geek w/Gearhead Complex
plain and simple. Where do these go??
oh, and do I need to use oil on the water pump gasket or the timing chain gasket? I want to be sure.
Thanks as always
Haha i duno, i had those left over also after my rebuild
Minus the waterpump one that is
ah no way. They gotta be for something ....right?? :2huh:
Good to know they weren't important, :D
A--could also be the distributor gasket o ring...maybe
B--
D--Oil pump gasket
Blue-water pump gasket
White--timing cover gasket
there also appears to be a rear main seal in the picture.
A- drain plug gasket
B-oil cooler to block gasket
C-cam sensor o ring, or distributor o ring if you dont know what a cam sensor is
D-oil pump o ring
Mike
After just rebuilding a complete motor myself....here goes.
a) oil pan drain plug seal
b) seal for the oil cooler to the oil pump
c) not too sure
d) oil pump to the timing cover
check with who you got the kit from for (c) and go from there.
1 - 10 of 10 Posts
